Asus UX325ea drivers problem
alecu72dts
System: Win 10 64
Battery or AC: both
Model: UX325EA
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
5 REPLIES 5
alecu72dts
Hi
my Asus Zenbook 11th generation processor after successful I install de OS the problems start to appear:
the chipset, graphic, audio and others drivers not work at all, they give errors like this: pnputil.exe - Entry Point Not Found
I I wonder why ASUS launches products on the market without also releasing software for these products.
NOW how can I resolve this issues to my new Zenbook to work properly??
Blake_ASUS
Community Legend II
Hello alecu72dts,
So you device came without OS?
So you were installing OS from Windows website? and then may you just run Windows update?
let it install drivers itself?
Below is the official support website of your model, for your reference.
ZenBook 13 UX325 (11th Gen Intel)|For Home|Laptops |ASUS GlobalThank you.
JBennett360
Blake_ASUS
Hello alecu72dts,
https://www.asus.com/Laptops/For-Home/ZenBook/ZenBook-13-UX325-11th-Gen-Intel/HelpDesk_Download/?mod...
Hi Blake.
I've recently got the same laptop. What's the best way to keep on top of drivers?
Use Windows Update, as a few of them and a BIOS update came through that.
Use MyAsus when it decides to open properly and load
Use the Asus support page and just download newer versions whenever they get updated?
Thanks
Blake_ASUS
Community Legend II
JBennett360
https://zentalk.asus.com/en/discussion/comment/141178#Comment_141178
Hi Blake.
Thanks
Hello JBennett360,
I would suggest to run the Windows update regularly as most and important updates are released from there and it will help you to install them directly.
That would be enough.
Please kindly understand sometime Windows update does not show the updates that fast as MyASUS and our official website, as it needs to go to Windows update release mechanism.
