Active stylus SA200H compatible with ASUS ZenBook Pro 15 OLED UM535QE-KY195W?
hansvanpoppel
Hi there,
I have a hard time discovering whether the Active stylus SA200H is compatible with the ASUS ZenBook Pro 15 OLED UM535QE-KY195W.
Does anybody have a suggestion or maybe even the answer?
Regards,
Hans
System:
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Falcon_ASUS
hansvanpoppel
Hi there,
Regards,
Hans
  1. System:
  2. Battery or AC:
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
@hansvanpoppel
The UM535QE is compatible with SA200H.
