Will an external nvme slot work for egpu?
Hi my laptop vivobook x142DA AMD ryzen 5 3500u Vega 8,  im looking to get an external gpu, but on my laptop the slot for m2 nvme is already installed by ssd, will a external nvme through usb work? If the external nvme doesn't work, I can see on google that the laptop can be installed with an egpu by removing the PCIE wireless and bluetooth card. If I remove it will I be able to surf and use bluetooth?
Falcon_ASUS
bimoappbaskoro
@bimoappbaskoro
Unfortunately, we can't guarantee the stability and compatibility of the laptop after installing the GPU by yourself. Sorry for any inconvenience it may be caused.
