vivobook s 14x oled s5402 screen problem
dohylee03
System: windows 11 22h2
Battery or AC:
Model: asus vivobook s 14x oled s5402
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:When I close and open the laptop or turn off and on the screen the vignetting effect appears on the screen like first picture. and when i reboot the laptop the vignetting effect disappears like second picture.
Pictures are in the comments section.
11 REPLIES 11
dohylee03
Also, conneting the laptop to an external monitor causes the same problem.
Falcon_ASUS
dohylee03
https://us.v-cdn.net/6031231/uploads/FJSJNS4IN3I2/20221120-221930-5b1-5d.mp4
@dohylee03
I have forwarded the information to the relevant department.
We will keep you updated and your consideration will be very much appreciated.
Falcon_ASUS
dohylee03
@dohylee03
Could you please provide the current version of the Intel VGA driver?
dohylee03
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/238037#Comment_238037
@dohylee03
Intel VGA driver version is 30.0.101.1368
dohylee03
@Falcon_ASUS
Changing the display settings or connecting an external display only while battery mode is in use causes vignetting.
When I connect the ac adapter, connect the external display, close and open the laptop, or change the display settings, the vignette disappears.
