Vivobook model K513EQ battery draining so fast
Toqa
I Bought this .#Vivobook model K513EQ few days ago and its not even lasting for 3 hours.. I enabled the battery saving mode and put all apps to sleep in background. I tried everything but its not even lasting 3 hours. its draining 50% in an hour.. what should I do.
Falcon_ASUS
@Toqa
If this is a newly purchased laptop, I would suggest you report to the dealer to confirm whether it is possible to return or exchange the product. Sorry for any inconvenience it may be caused.
