Splendid and True2Life options missing
3dmikee
Rising Star I
System: Win11 x64 Home
Battery or AC: both
Model: M513UA (noOS)
Frequency of occurrence: always
Reset OS: new install
Screenshot or video:
Detailed description:Hi. I bought this laptop yesterday from authorized seller. After installing the Windows and all the drivers from the Asus official website i 've noticed that MyAsus does not have the Splendid & True2life feature promised by the specs. I contacted local Asus support, they said to clean Windows install and install the drivers again, but this path has already been passed after purchase. I already tried reinstalling the graphics driver, checked for Windwos updates, BIOS update, reinstall MyAsus, Splendid, SystemControlInterface, disable HDR. However these settings st
ill gone. Any solution?
3dmikee
Rising Star I
I've got the solution. To prevent that from happening just delete folder located at
c:\programData\ASUS\ASUS System Control Interface\AsusOptimization\Splendid
and finally driver installing correctly
Falcon_ASUS
3dmikee
@3dmikee
Thanks for your updated and sharing of your message.
