Sound problem
System: Windows 10
Battery or AC: Battery
Description: Hello, I have an Asus Vivobook S510UNR Laptop. My laptop sound is too low to listen without headphones. I have updated all my Audio drivers but nothing seems to work. What can I do? Any help?
Model: Asus Vivobook S510UNR
Frequency of Occurrence: Always
Reset OS: No
Hello, I have an Asus Vivobook S510UNR Laptop. My laptop sound is too low to listen without headphones. I have updated all my Audio drivers but nothing seems to work. What can I do? Any help? Thank you!!!
RAJU_MSC_MATHEM
Zen Master I
Last edited by RAJU2529 on 2019/5/2 10:16 try to use largest audio driver and install asus audio wizard software. Then configure the Audio wizard with little settings. Normally after installed audio driver, sound volume will be preset to 67%. but you can configure better sound through Audio wizard
Blake_ASUS
Community Legend II
Hello m.lokeshvenkatasai, I'm not sure about your description. Do you mean the volume is low (not loud enough even you already turn to maximum) or you mean the sound/tone is low? Thank you for messaging us. Have a nice day.
