Need sata cable for X415EA_X1400EA
JBL121
I want to install  a 2.5" sata drive in my Vivobook X415EA_X1400EA. I read there is an A and B connector.
Which one do I need. I dont want to order one and find out I needed the other.
Thanks
JBL121
Falcon_ASUS
@JBL121
You can install a SATA III, 7mm, 1TB hard drive.
I have the HD but need to order the sata connector cable. There seems to be 2 types, A and B.
I need to know which one to order.
Thank you for any responses.
@JBL121
The SATA hard drive interface is standardized, and this model already has a hard drive inside. Therefore, you should only need to replace the original hard drive with the new one.
