Myasus is showing there may be issue with fan.
sknewtons330
I have recently buyed Asus vivobook s14 k403fa.
I have done hardware diagnosis it is showing there is isusse with fan. I have not used it for one week . I have uninstalled myasus and download new from Microsoft store then also it is showing there may be issue with fan . What should I will do is this a software issues or hardware issue . I am so worried about it .help me
33 REPLIES 33
sknewtons330
Thanks black_asus .
sknewtons330
Blake_ASUS
Dear both,
Please kindly check if your BIOS is up to date
and then please reinstall your "ASUS System Control Interface" driver
and the reinstall MyASUS APP.
After updating bios and user interface myasus app runed only one time . Whenever I try to open it I show loading and close automatically . I have uninstalled that and install new one then also it is not working. What's going on.
emancipaturadu
Blake_ASUS
https://zentalk.asus.com/en/discussion/comment/125987#Comment_125987
The latest BIOS version is 315. Please kindly double check if you have updated to 315.
https://www.asus.com/Laptops/ASUS-TUF-Gaming-FX505DD-DT-DU/HelpDesk_Download/
I checked last night and I have the 315 version, gamed a little bit with some PES and Watch Dogs 2, temperatures are normal (75-80 celsius for CPU, 70-75 for gpu) on balanced mode, the fans are reaching 5000 rpm when in turbo, I think they are good but myasus keeps telling me that there might be an issue with the fan
emancipaturadu
Blake_ASUS
oh and one more thing, whenever i start a game, there is some high pitched noise coming from the laptop and it goes away when i "alt-tab" to the desktop, i searched online and i think this is called "coil whine" and i want to ask you if it's a normal behaviour
I got my Asus tuf fx505dt yedterday. It shows issue with fan in myasus app. I have already installed 2.2.41 version and also updated the bios still get the same issue. What to do ?
