how do I somehow enable Fan Control in MyAsus to Performance Mode with device flipped 270
waj1990
I have Asus Vivobook S14 Flip.. I like to use it flipped 270 degrees, with full keyboard and mouse in front of device. I need the extra power and the air flow is even better facing upwards..
Can you please suggest ways to enable Fan Performance Mode (MyAsus app).. to get best CPU power?
I tried to use ThrottleStop app but it says 'cpu not supported'
Falcon_ASUS
@waj1990
The relevant settings in MyASUS have already been adjusted.
I would recommend that you refer to the instructions regarding the "Fan Profile" in this FAQ post.
MyASUS – Device Settings
waj1990
I have this
