DISPLAY SETTING ON VIVOBOOK N7400P
michanisty
I adjust the displlay setting on my laptop Vivobook N7400P on 250% scale because the default 100% display show a very tiny fonts and everything (while the recommended setting is 200%).
By adjusting to the higher scale, I found that some of the games I installed could not display correctly, they become too big in the screen, and I supposed it is because the display is over 100% scale.
I found it the display of the game will be back to normal when I changed the display setting in to 100%, but it is very troublesome since the whole system would be in a very tiny size.
Did I miss anything to install?
Falcon_ASUS
michanisty
@michanisty
Does this happen to all games, or does it only happen to certain games?
In my understanding, If the settings of the game are correct, it will adjust itself to the best resolution when playing.
Could you please tell me the name of the game you are playing?
In addition, please tell me the system version, BIOS version, and graphics card driver version you are using.
michanisty
Several games I installed from BigfishGames.com (Time Management Games), have inproper display, some so small, some too big.
For graphic card, NVIDIA GeForce RTX3050
I already update all the driver I can get.
I also got a hold on upgrading to Windows11 due to Intel Smart sound issues compatibility.
Please check system information in the picture I attached.
thank you
Falcon_ASUS
michanisty
thank you
@michanisty
Could you please provide me with the name of the game you actually installed?
In addition, please help to provide the picture of the screen with the problem of display size for further confirmation.
