Display Issues in Laptop
Sakthivel1
I bought my ASUS VIVO Book laptop on Dec-22. We can see the dark blue color in the laptop display screen on the top left corner. We need to know if we need to change the laptop display.
#ASUS #VIVOBOOK
Falcon_ASUS
@Sakthivel1
Since we cannot verify the actual condition of your laptop, if there are display abnormalities on the screen, we recommend reinstalling the graphics driver. If the issue persists, I would suggest you bring back your laptop to our service center for further confirmation.
camilasaunder89
Rising Star I
Display issues are caused due to outdated drivers. You can update it using the manufacturer's website or download Advanced Driver updater for this. Other than this, if your laptop is facing a flickering problem then reboot your laptop in Safe mode.
