03-13-2021
03:56 PM
- last edited on
01-16-2024
02:01 AM
by
ZenBot
03-13-2021 07:39 PM
cristian9918is same problems happens in bios display mode and in Safemode also.
- System: Windows 10
- Battery or AC: Battery
- Model: X505Z
- Frequency of occurrence: Every time it turns on
- Reset OS: Yes, 02/02/2021
- Screenshot or video:
Detailed description:
Hello everyone.
I have had a problem for a long time with my laptop screen. I will describe what happens.
I turn on the normal laptop, and lines or small dots appear on the screen, they do not let me see anything, nor does it load (like the image). After a few hours, it passes faster when I put blank images or videos in full screen, it is solved, but not completely, the white lines decrease.
After more hours, the problem is completely resolved, but after the screen turns off, the white lines reappear.
When I stream content via HDMI, it works on the other screen normally.
What I can do? Buy a new screen?
Display failure. Vertical white lines or dots
03-14-2021 07:35 PM
03-15-2021 02:08 AM
