09-03-2020 01:45 AM - last edited on 01-16-2024 12:45 AM by ZenBot
09-03-2020 07:14 PM
09-04-2020 02:32 AM
Blake_ASUSim using windows 10 (64 bit) Asus Vivobook X505ZA 8gb ram, Amd Ryzen 5 2500u with Amd radeon vega mobile gfx.Hello Shreyansh,
May you provide more information?
and how did you find out this issue? using which program?
09-07-2020 08:39 PM
09-08-2020 02:28 AM
Blake_ASUSyes the fan and heat radiation working fine in my laptop. everything is slow as you can understand how can anything work smoothly in a speed of 0.38ghz.Hello Shreyansh,
Please kindly check if your BIOS and windows are up to date.
So no matter which function your are using now, all are slow?
is the fan and heat radiation working?
