04-30-2020 02:28 AM
04-30-2020 07:26 PM
FrankvtCheck the technical specifications of your model.
- System: Windows 10
- Model: S512FL-BQ563T
I would like to use a docking station on my S512FL-BQ563T, which would connect two USB 2.0 devices, a second screen (monitor) via HDMI and preferably a network cable for wired internet. The docking station could connect to the USB-C port.
I already had a similar dock I used for my Macbook (without network). However, that one does not seem to work on the Vivobook. Is a second screen even supported through USB-C? If so, do you have advice which dock to buy?
Connect a second screen using USB-c
05-02-2020 01:51 AM
05-02-2020 01:57 AM
FrankvtSome usb C 3.1 port are charging purposely. .some usb C3.1 Port are capable of connecting display. some model laptops are supported.I cannot find that information. It only says USB-C 3.1. No idea if that would be good enough for an external display and possibly network cable.
05-03-2020 11:36 PM
