Can't connect to monitor via USB-C
albina_naum1
System: Windows 10
Battery or AC: Battery & AC
Model: TP412FAC-EC379T
Frequency of occurrence: every time i try to connect
Reset OS:
Screenshot or video:
Detailed description:I had just purchased a Phillips Brilliance 241B monitor and the only way i seem to connect to it is via HDMI. I've tried to connect directly into the laptop with the USB-C cord supplied with the monitor, I've tried to connect via the docking station using the DisplayPort cable and nothing seems to work except when i connect using the HDMI cable.
albina_naum1
Screen snapshot included
Blake_ASUS
Community Legend II
Hello Albina,
The USB C port on this model does not support Display export.
