Battery life - Vivobook pro 15 OLED
saarlevi
System: Windows 11
Battery or AC:
Model: m3500QC
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
I made a battery health report, seems like my battery life is getting short very quickly.
is that normal ?
thank you
Falcon_ASUS
saarlevi
  1. System: Windows 11
  2. Battery or AC:
  3. Model: m3500QC
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
is that normal ?
thank you
@saarlevi
If you are concerned about the battery life,  I would suggest you bring back your laptop to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
http://www.asus.com/support/CallUs#
