Battery issue
RajendraKumar
System:
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hi sir,
actually when keep charging my battery always showing indication like slow charger .
as show in figure
8 REPLIES 8
Blake_ASUS
Community Legend II
Hello RajendraKumar,
Does the slow charger shown after the battery % is higher than 80%? or even at low %?
When did this start to occurred?
Which model do you have?
RAJU_MSC_MATHEM
Zen Master I
RajendraKumar
  1. System:
  2. Battery or AC:
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Hi sir,
as show in figure
Battery issue
Why yellow mark is showing , use windows power builtin troubleshooter.
normally after 80% , battery charges little bit slow, so its takes more time and normal. Use Asus charger comes with laptop only , check the loose connection of powerplug to ac adapter ,
moremayur436
Sir my battery issue is there and the battery is coming down very fast plzz tell me something plzz
RAJU_MSC_MATHEM
Zen Master I
moremayur436
type the following commands in cmd with admin rights
PowerCfg.exe /ENERGY -output C:\Energy-Report15-09-2020.html /duration 240
PowerCfg.exe /BATTERYREPORT -output C:\Battery-Report15-09-2020.html /duration 14
upload .html files in online storage , then share the link
