Battery issue
- System:
- Battery or AC:
- Model:
- Frequency of occurrence:
- Reset OS:
- Screenshot or video:
Detailed description:
Hi sir,
actually when keep charging my battery always showing indication like slow charger .
as show in figure
Comments
Hello RajendraKumar,
Does the slow charger shown after the battery % is higher than 80%? or even at low %?
When did this start to occurred?
Which model do you have?
Why yellow mark is showing , use windows power builtin troubleshooter.
normally after 80% , battery charges little bit slow, so its takes more time and normal. Use Asus charger comes with laptop only , check the loose connection of powerplug to ac adapter ,
Sir my battery issue is there and the battery is coming down very fast plzz tell me something plzz
type the following commands in cmd with admin rights
PowerCfg.exe /ENERGY -output C:\Energy-Report15-09-2020.html /duration 240
PowerCfg.exe /BATTERYREPORT -output C:\Battery-Report15-09-2020.html /duration 14
upload .html files in online storage , then share the link
I am using vivo book s15, from last 7 months and , my battery is draining to fast , 2-3 % in a minute, and processor gets heated even in minimum usage of applications , from 100% to zero in just 45 minutes. Any one having such issues or know how to solve it please do reply.
Thanks for the best laps you have provided and i love them but battery is draining too fast, is there any solution for it or any other battery will fix for it. Any suggestion will be apprciated.
see my previous reply , I given some commands execute those, send the results, I need the verify which are the applications eating your battery power.
