06-28-2020 07:26 AM - last edited on 01-16-2024 01:03 AM by ZenBot
06-28-2020 09:21 AM
InnoXenTI have to be honest, I am not sure what the problem is you're stating? I can only see you typing t and u and the bit where you're circling on the keyboard. From the video, what are you trying to achieve?Getting touch problem when phone heats up here u can see its not working in the middle of this two wrds (t and u) the whole line stops working after phone cools down
It works normally again need solution please..
https://us.v-cdn.net/6031231/uploads/DO8IOYYAQLAS/2020-06-28-19-49-57.mp4
Touch stops working when phone heat's up..
06-28-2020 10:48 AM
06-28-2020 10:53 AM
ronald1985I cant press Y i need to rotate my screen and then i can type properly like a whole vertical y part of is screen not working. Like if i touch der its showing 2 touch marks like as u can see in the videohttps://zentalk.asus.com/en/discussion/31160/touch-stops-working-when-phone-heats-up
06-28-2020 10:55 AM
InnoXenTSorry, I still don't understand what the problem is.This is the problem iam facing the touch in between t and u is not working
