SOLUTION !!! Possible solution for call of duty on Android 10 so that it no longer hangs
gusta_cm
Go to developer options and go to Game driver preferences and selec system graphics driver and supposedly the game would no longer cause problems ?
Cetorca
Hi Gusta_CM, did you tried?
What other things on the phone change with that option?
Swampdonk
This was not a working solution for me yes I too found and tryed you want best fix I've come to find by trial and error downgrade firmware to 9 from Asus website then you also can modify xmode performance aswelll as high frame rate in-game and medium graphics if you seam to lag with network drop fps down one more notch for stability with fps
Swampdonk
Check Xda for info on downgrade proccess
