PUBG 120FPS problem??
AL1EN
Guys, does anyone have an fps problem after the recent pubg update, the same as on 120fps release? sens is working really bad, 120fps is available but the meter shows that it's around ~91, the only playable solution for now is to turn the smart adjustment to minimum and play with 90fps. btw I've still never updated to .71
CucKooo
Same problem, nothing helps at all.
CucKooo
But today i have already solved it for myself. Recently i imported official settings named like A14 with cooler (120 fps) but i have A13. I changed it to A13 with cooler and downloaded the last 241 patch on Android 13 for rog phone 7. Now everything works fine 🙂
