Rog Phone 2 - Security Lock Issue
sahil_tekken7
Hello 🙂
I recently got the ROG Phone 2 (8gb) & absolutely loved the device . Everything is working Very nicely.
The only main issue I'm facing is the security lock issues . Neither PIN / PASSWORD / THUMBPRINT are requested to unlock the screen even after completely setting up any one of the above .
Just a swipe unlocks the device , making this a security risk .
Any help or comments would be highly appreciated !
13 REPLIES 13
sahil_tekken7
rickymohk
Check if smart lock is enabled?
Hello Again 😄
Just wanted to thank you.
That was indeed the problem - on body detection was enabled .
My sincere thanks to you & for your help !!
sahil_tekken7
Thanks for all the responses.
Thankfully the issue has been resolved , which turned out to be more of a negligence on my part .
My apologies & appreciation for the help !
Thank you All 🙂
V3KSCK
sahil.tekken7
https://zentalk.asus.com/en/discussion/comment/38823#Comment_38823
Hello Again 😄
Sir I am having the same security issue .It unlocks just by swipe and even I have not enabled smart lock.Kindly help!
V3KSCK
V3KSCK
https://zentalk.asus.com/en/discussion/comment/38949#Comment_38949
My phone is asus rog 2.
