ROG Delta (USB C headphone) not working with ROG Phone 2
bishwa_roy
Well, this is something different. Asus makes these RGB headset and have been portraying them as compatible since the ROG Phone 1. It states clearly that ROG Delta is compatible with USB-C enabled devices. Well ture, they were compatible, but since the last FOTA update of my phone, the usb c headphones don't work with my ROG phone 2 anymore. Not from any of the usb ports (bottom/side).
23 REPLIES 23
abhi3278
I am using rog phone 2 I trying to connect my 3.5 mm jack earphone with rog into side mounted thpe c port via type c to 3.5 mm connector but it doesn't support. Why
abhi3278
Sane problem I am facing
LP_ASUS
Community Legend I
abhi3278
We can log your phone to try and figure out what's going on with this issue. I haven't hear back from @bishwa_roy yet, we haven't been able to replicate this problem.
LP_ASUS
Community Legend I
Suhaib
Hi, I connected My Rog Cetra earphones to My ROG phone 2, and it worked for like 20 min, then suddenly stopped, and when I reconnected The Rog Cetra to my ROG phone 2, my ROG 2 not detecteded it.... I've tried other USB-C headphones and the phone is no more able to detect it.
We can log your phone to find out what's going on. I merged your thread to this one because it seems to be the same issue, USB-C headphone detection.
Suhaib
LP_ASUS
https://zentalk.asus.com/en/discussion/comment/28565#Comment_28565
and how you can log to my phone?
