06-26-2020
12:03 PM
- last edited on
01-16-2024
01:02 AM
by
ZenBot
07-01-2020 06:25 PM
MelquiYour right. Its not good to do this all the time. However, I will occasionally calibrate my battery. To do this one has to completely drain the battery. Plug it in and turn it. Don't unplug until it reaches 100%. Repeat all the steps above 1 more time. Afterwards battery calibration is completeLet battery discharge until 5% is very bad to battery!
akhilj66I've thought about turning off battery optimization, adaptive battery as well as using the "plugged in at home" hardcore tuning found on the zentalk forums for call of duty mobile once my battery hits 5%. Wondering if that would make a difference. I did discover if I turn off battery optimization and adaptive battery things only start to lag at 3% versus 5%For me it's 3%, I have tried all the suggested hacks, none of them works.
You can however charge the phone while using and when it reaches 4% or 6% in your case, phone starts acting normally.
This is normal for all phones to conserve battery in the end, just Rog 2 lags little bit more. 3% or 5% try not letting go below 15%, battery will remain healthy for longer time.
