help
MAX-VIP
I have a Rog Phone 6D phone, my phone version is 12. I have not received any update for the phone. Well, my phone has a high temperature. When playing pubg, the temperature reaches 47 and the battery drains quickly. Why else would I want to... Manual update. Give me the latest update or a link to update the phone. I cannot play due to the extreme heat
0nly3sy
U can maybe try to update Ur phone to version 13 with beta and try it again out. If it's still overheating for some reason then check out if ur room temperature is to hot which can cause the phone getting hot that it should help, if it still happens then u need to visit service centre to look at Ur phone and then repair it, maybe it's also because of ur battery that's getting hot or did u overclock ur phone?
