10-23-2019 11:05 PM
12-09-2019 05:54 AM
12-09-2019 06:32 AM
12-10-2019 10:06 AM
bunnyfastardThis is a similar but separate issue. If your Air Trigger is activating when you touch the back of the phone, that indicates a hardware issue and we recommend you visit a service center. I understand that you have already had the phone repaired, but if you are still seeing the issue you will need to have it repaired again.**TEMPORARY SOLUTION**
Hi All,
For people facing an issue with trigger working even when you touch the back of the phone.
I've found out a lame but working solution for now. I recently ordered and applied a skin for my phone.
Turns out, the trigger does not fire now when i touch the back of my phone (now with the skin). So look for some material and place it at the back of your phone (a piece of thick paper) and try if the trigger works then. If not, Voila! ? Just buy a skin or a small paper cutout.
I know this is not a permanent solution, but a temporary fix until the team
comes up with a solution.
Please try and let me know if this works for you.
12-10-2019 10:09 AM
nightsilvanceWhat percentage of the time is it happening compared to before? 25, 50%? Is it after long gaming sessions when the phone is hot, or at any time? What kind of feedback can you give us about before and after the software fix?Mine is global 12/512 version. After the previous update, the frequency that the issue happen to me is greatly reduced. But once in awhile it still happens.
12-10-2019 10:35 AM
LP_ASUSHi,https://zentalk.asus.com/en/discussion/comment/33271#Comment_33271
