ROG 8 - Camera Problem
Khaeru
Since the latest firmware update on June 2024, i have insane change of camera feature. Not in good ways but in ridiculous worst way.
1. Flip button to change from rear camera to front camera is gone. Now i can't do selfie photoshoot.
2. Wide camera 0.7 is gone. Now it only give me 1 and 1.4. And the quality itself is now sooo much worrrsttt than what i've got at first. There are 4 cameras is embedded on this phone, now is only 1 camera is functioned, the rest are dead.
3. Trying to get 4K video ? Now is impossible. The camera will stop responding whenever i want to try it. All the premium feature to get high quality video is gone.
4. This is the most silly part. Whenever i want to pay something by scan QR barcode, my phone will use the front camera instead of rear camera.
Tried to solve this by run 'Factory Reset' and yeah no change. I dont know whether this is solvable bug that might be can be solved when the next firmware or this is hardware issue.
Several days ago i went to Asus Service Center and tell everything about this issue. And they dont know the causes, they only suggest me to left my phone there and let them check why for 5 days working hour. And no guaranty of new device replacement only for spare part.
Any simillar problem with me guys ?
Btw me in Indonesia.
25 REPLIES 25
Ohenry02
Yes , juts fix it, looks like the cellphone have something lose inside, so when I restart and when is turning back on again, I just squeeze the phone most likely in the area where the connectors for the camera are, is in the bottom of lens and in the middle of the phone that same side, and it work again but when the phone loses connection, have to restart and squeeze again, I think the glue that was used to seal the rog 8 is not strong enough for this phone. I have fix camera already with this method like 3 times already and discovered like a week ago. Hope this helps, let me know if it work.
Have some one else try this? Still works for me.
Can you show us where you pressed? Thanks!
 just did it again, clear/delete cache before restart. Hope it work good luck.
Narendra_AR
My ROG 8 has the same problem
