Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
229 REPLIES 229
No. This is not related to the Android version. This is new hardware which needs more tuning. Rog phone 7 works fine on A14.
Sure? Air triggers and cooler buttons are fine on A14? I didn't update the phone(ROG7) yet because I didn't hear any good news about that. What games u tried the phone?
Zцlц
Dear Asus? Do you know about the issue? Is there a fix coming soon? Overall touch is not responsive enough compared to my ROG7 not just the air triggers are weird. Last update kinda fixed the cooler buttons at least.
errorTamilan
Wheather is it work or not ?
Check ?
New air trigger update, let's see if it works this time , new settings in armory crate
