Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
😂 Yesterday you Said they Work amazing
Read full storey it's amazing means very very worst 🤣🤣🤣
GarbeGD
The truth is that I really like both the design of the Rog Phone 8 and the Asus brand itself, but honestly for this price and that its strongest point which is gaming presents a problem as serious as the AirTrigger not working properly is something very worrying.
Personally I will wait until the end of this month to see if Asus gives a solution, if not, unfortunately I will have to buy the Red Magic 9 Pro.
Translated with DeepL.com (free version)
Надо понять идёт эта проблема от Андроид 14 или от самого триггера. Триггеры реагируют на нажатие , но действие бывает или не бывает во время игр. После обновления триггеры работают лучше чем были из коробки, но есть к чему стремится. А сам телефон крутой, мне нравится, он выглядит брутально
Oh ok Android 14 to 13 downgrade firmware link share here
