Air Trigger Problem ROG 6 After Update
anggitpras
Hi all,
I'm facing issue in ROG 6 build number .260 where after the update, my air trigger is not as responsive as before. When I use it, it felt like released suddenly, where my finger was still push the trigger.
My phone was in good condition, not ever been broke/falling down. Somewhat, after the update, it bring the error.
Is anyone face the problem same with me?
Thanks
95 REPLIES 95
That's a very good tip, thank you very much. I will try that.
I tried this but i don't know how to install the previous version...i followed those steps and doesn't work....
Directly following the instructions given from the website won't work if you will try to downgrade a version since the phone will only recognize a newer version of what you currently have. It's still possible to downgrade however you need some advance tools to do that (basically debugging + presence of a PC device to run certain commands).
So i can do it in a store for example?
Cause i don't see any type of help here from the support
I want to use the previous versions that i don't have the air triggers problems at least...so i can play normaly...
If the technician is good and will accept your request then go for it but it comes with a greater risk (brick or bootloop). The best and unfortunate option is to really wait for a hotfix which we don't know how long it'll take.
