Wifi problems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-16-2023 02:58 AM
Waiting for 2 days now. 2 days back recived 2 updates "sistem stability" or somerhin like that.. after these updates i cant Connect wifi , tryed everything.. even factory reset, nothing works.. still Waiting for some update to fix this, i dont want my phone to end up in a service centre.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-17-2023 01:55 AM
There is no OTA update to fix this issue. You should reach nearest service centre for a motherboard replacement, and it is the only solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-20-2023 06:22 PM
@HExu
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
