Wifi and hotsopt not working
ruckys
I haven't downloaded the last update since I heard the problem with it, but a couple of days ago my mobile got rebooted and updated, the very next day the wifi and hotspot are not working. even it got power-off automatically a couple of times. When I spoke over the text messages with the agent, They said that I need to send the unit to them for inspection which would cost me around $85 and I should again pay for the repair cost, they will change the motherboard for this problem.
My question is why should I pay for the unit damage that I didn't cause, there is no service center near me here in Dallas, USA.  This mobile is so important for me as a memory, but it's been only 2 years since I bought it and I cannot use it after this issue. it is so frustrating for me right now that I don't wanna through away this mobile but if this issue doesn't resolve I don't have any other option than carrying this mobile to consumer court.
10 REPLIES 10
@Thezaret
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
