Vibration issue, Proximity sensor not working
Ali_Merchant
Model Name: ROG Phone 5
Firmware Version: 18.0840.2107.151
Rooted or not: No
Frequency of Occurrence: Daily
No vibration while receiving call,
But I can feel vibration on Tap & Typing.
After Formatting, All worked back to normal for one day but then again same issue from next day...
9 REPLIES 9
ronald1985
Community Legend I
Ali Merchant
  1. Model Name: ROG Phone 5
  2. Firmware Version: 18.0840.2107.151
  3. Rooted or not: No
  4. Frequency of Occurrence: Daily
Go to Calculator and type in .12345+=
Do single test and perform the vibration tests and Proximity sensor test.
If these fail, then you need to go to service centre. If pass, try in safe mode.
ARP_ASUS
Community Legend II
Hey,
Please confirm after trying the above.
XBlacklisted
Same issue after updating, I did factory reset and all working fine for 1 day after vibration didn't working now
ketoweb
@ARP_ASUS Hey man, I am facing the exact same problem and it was introduced with the .151 update. The same proximity sensor issue and phone not vibrating when receiving a call. This is very frustrating, what should we be doing?
Did the calc test also, the sensors are failing. But this is a software issue because haptic feedback works fine. The proximity issue can be fixed via calibration.
How do we report this to Asus?
