07-30-2021 04:05 PM
08-06-2021 04:01 AM
08-06-2021 10:14 AM
FunBike31Do you know which router they give with 1 Gbps plan ?IP v6 is already disabled
Unfortunately this Nokia router is AIRTEL specific and important configuration points can only be done by AIRTEL, such as bridge mode or the firmware update.
I am not sure that the dual 2.4 and 5 GHz mode is possible on this router to use both frequencies simultaneously to increase the speed but rather 2.4 for devices that do not accept the 5 GHz frequency and 5 GHz for more devices recent.
There is a competent community on broadbanforum, you should submit your issue here
I can't submit a full link yet, you add https: // broadbanforum.co by removing the spaces
/threads/nokia-g-140w-f-bridge-mode.199535/page-14
