04-21-2021
05:44 AM
- last edited on
01-16-2024
01:06 AM
by
ZenBot
02-01-2023 01:40 AM
Loose SIM card slot will caused the card losing the connection with the reader of the device. Solution: You can try to apply some pressure to the slot check again if the slot hold the SIM properly. 3. Dust over the slot and SIM card reader making the slot incapable of reading the card properly.
Regards,
Will
02-02-2023 05:10 PM
Hi @nfahmi1988
I'm so sorry to hear about this issue! Can you please back up your data and perform a data reset:
[Settings] > [Backup & Reset] > [Reset Phone]
If this does not work, it will be best to visit a service center or contact the place you purchased from to get a replacement.
Thank you!
