Scheduled charging and steady charging not working as expected
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-25-2021 03:56 AM
Model Name: Asus Rog 5 Ultimate
Firmware Version: WW18.0840.2106.86
Rooted or not: rooted
Frequency of Occurrence: every time
When I try to use scheduled charging or steady charging it does not work as expected. As soon as I plug my device, hypercharge is on and after 30/40 minutes my device is fully loaded. No matter when, no matter in what conditions.
I thought steady charge would slow the charging speed and planned charge would plan when the device is actually charged but no matter what I try and what settings I use it always displays "steady charge" and "scheduled charge" via notifications but the hypercharge icon appears.
Did I miss anything?
It's basically the same as this one https://zentalk.asus.com/en/discussion/34315/slow-charging-and-schedule-charging-is-not-working-as-e...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-30-2021 09:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-31-2021 03:14 AM
I just tested my ROG Phone 5 running the .151 firmware using both a 30W charger and the stock 65W charger. Steady charging (and ultra steady) works as expected for both chargers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-31-2021 03:18 AM
FunBike31You should get a notification asking you if you want to switch system mode when your battery drops below a certain level.I forgot an important point, there is no low battery warning, nor automatic switch to maximum power saving.
In games, started at 25% charge, the phone turns off at 0%
You can also set your device to automatically switch to Ultra durable mode when your device dips below 3-20% battery. (Settings -> Battery -> Battery Management -> Low battery power-saving)
If you do not receive any warning when playing games it might be because you have enabled the 'block notifications' setting in Game Genie. It's also possible that your current scenario profile forces a certain system mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-31-2021 04:32 AM
ZT-6ba223c6Poderia fazer o teste eu carregador para ver se os dois módulos de bateria estão funcionando???
- Model Name: Asus Rog 5 Ultimate
- Firmware Version: WW18.0840.2106.86
- Rooted or not: rooted
- Frequency of Occurrence: every time
Na calculadora stock use esse código ",12345+"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-31-2021 05:08 AM
SMMI test will not show the same results as a power meter would (just checked). You should however be able to see a clear difference in the current reported by SMMI when you switch steady charging on/off.
