Performance issue After motherboard replacement
hp9976802431
Rising Star II
1.42ghz only throttling(x mode also) In Game play and stuttering issue,can't play smooth .Very worst performance plz fix in update.
53 REPLIES 53
hp9976802431
Rising Star II
Sarkiri
It's the firmware and software issue and not a thermal paste issue.
There is a way to achieve the full 2.84Ghz through Advanced Hardcore Tuning through Game Profile Scenario but now you'll have to make a custom profile for all of the games if you want to get the full performance as intended.
These performance profiles like X-Mode, Dynamic, Ultra Durable and Advanced are no longer working, they are all clocking at the same CPU and GPU speeds now.
I had just tried Genshin Impact with the highest settings with the cooler on and a custom Advanced Hardcore Tuning Scenario Profile and I was able to achieve the full 2.84Ghz and my FPS increased a lot, and the system temperature also seems a few degrees cooler with 52C Max than my original motherboard which goes up to 56C even with the cooler on. The phone also does not feels as hot to touch as compared to my phone before replacing the motherboard.
My CPU and GPU temperature never went above 65C and the System temperature 52C while playing Genshin Impact when previously with the original motherboard the CPU and GPU temperature would go above 70+C. so it is not a thermal paste issue but the firmware issue.
When using the Advanced Hardcore Tuning in Game Profile Scenario the profile would not work even if I apply it. I have to open the game first and then lock the screen using the power button and then unlock and resume the game for the settings to work to achieve 2.84Ghz otherwise the CPU would downclock to 1.42Ghz as before. I had also tried the same method of locking the phone using the power button with with X-Mode but it doesn't seem to work. The System Modes found in Settings - Battery - System Modes that you see in Armoury Crate like X-Mode, Dynamic, Ultra Durable and Advanced are also not working. So the System Modes and Armoury Crate are bugged as well.
And also one important thing to note. The CPU and GPU will always show the same temperature as shown in the picture because the GPU is integrated with the CPU, so if the CPU heats up the GPU will heat up as well, just ignore the sudden spike in CPU temperature when you first open Armoury Crate, wait for it to stabilize. Its then sensor trying to read.
System Modes and Armoury Crate are bugged yah bro your assumption is correct even Any setting xmode, dynamic ,ultra or hardcore tuning ,gaming tuning all level is go to 1.42ghz only.developers Plz fix this in update
Sarkiri
I don't have this Xmode+, only XMODE! How to activate that please assist..
Sarkiri
Rising Star II
MinerQuarry
https://zentalk.asus.com/en/discussion/comment/200704#Comment_200704
Can you share the scenario profile for achieving full 2.84 Ghz? I don't understand what the options meant inside the custom profile.
Sure, I need to make a few adjustments first then I'll post the profile here once it ready.
Sarkiri
Rising Star II
hp9976802431
Yes, both System Modes and Armoury Crate settings X-Mode, Dynamic, Ultra Durable and Advanced settings are bugged, they are all clocking the CPU at 1.42Ghz. The Advanced Hardcore Tuning is also bugged it doesn't apply the settings when you start the game. You have to start the game then lock the screen with power button then unlock the phone and resume the the game to apply the settings.
Sarkiri
Rising Star II
আই টি ইন্দ্র
You need the ROG Phone 5 AeroActive Cooler to enable the X-Mode+, when you attach the cooler, the X-Mode+ will active itself.
