Performance issue After motherboard replacement
hp9976802431
Rising Star II
1.42ghz only throttling(x mode also) In Game play and stuttering issue,can't play smooth .Very worst performance plz fix in update.
53 REPLIES 53
hp9976802431
Rising Star II
FunBike31
I just took it out of the box, I launched several gaming sessions, from the temperature of 30 ° to 41% the CPU does not take off from 1.42 GHz, this smartphone is just unusable now.
Same here armory crate level 2 performance Gaming tuning with out aero cooler 1.42ghz only.Level 3 performance with aerocooler 1.56ghz only.lag game play
hp9976802431
Rising Star II
Danishblunt
https://zentalk.asus.com/en/discussion/comment/200575#Comment_200575
If the problem is indeed a bad repaste all you need to do is go back to the service center and ask for proper repaste or if you feel like you can confortably open the phone no your own you can buy a good thermal paste like kryonaut and do it yourself.
Is not a thermal paste problem my device not heat up maximum it goes like 40°c or 42°c. If device is thermal issue its says warning notification see the online refrence screenshot
Danishblunt
Hall of Fame I
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200581#Comment_200581
you can have system temp of 30c and your CPU can still be 105c. System temp is irrelevant, all you should care about is your CPU temp NOT your system temp.
hp9976802431
Rising Star II
Danishblunt
https://zentalk.asus.com/en/discussion/comment/200586#Comment_200586
How to find our system temp .You also say perfdog method any another method to find is a thermal paste issue or not ?
Danishblunt
Hall of Fame I
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200587#Comment_200587
The system temp is the temperature you see on armory crate (40-42c). Perfdog is by far the best way of testing your temps while gaming, however you can also use "CPU Throttling test" on play store, remember to turn on temperature in settings when launching it, then you can post a screenshot after running it for 10 minutes.
