Performance issue After motherboard replacement
hp9976802431
Rising Star II
1.42ghz only throttling(x mode also) In Game play and stuttering issue,can't play smooth .Very worst performance plz fix in update.
53 REPLIES 53
Danishblunt
Hall of Fame I
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200491#Comment_200491
I also went to service center they done factory reset my phone.But the problem remains now .what can I do now?Is it gaming phone really?
I assume whats happening here is a bad repaste, hence the CPU throttles heavily. Try to play your games while using perfdog and monitor specifically your CPU temp. If my assumption is correct, your CPU should hit 102c or 105c.
hp9976802431
Rising Star II
Danishblunt
https://zentalk.asus.com/en/discussion/comment/200530#Comment_200530
Ok I accept your assumption.But over all phone have that the repaste problem?if there is any option to identify problem other than that.
hp9976802431
Rising Star II
Danishblunt
Ok if repaste problem the phone says temperature warning but not showing any temperature notification?
Danishblunt
Hall of Fame I
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200572#Comment_200572
If the problem is indeed a bad repaste all you need to do is go back to the service center and ask for proper repaste or if you feel like you can confortably open the phone no your own you can buy a good thermal paste like kryonaut and do it yourself.
FunBike31
Community Legend I
I just took it out of the box, I launched several gaming sessions, from the temperature of 30 ° to 41% the CPU does not take off from 1.42 GHz, this smartphone is just unusable now.
