10-17-2020
11:46 PM
- last edited on
01-16-2024
12:33 AM
by
ZenBot
10-29-2020 02:33 AM
itopinonavevanonipoti95Yea ,i have that too from the begininghttps://zentalk.asus.com/en/discussion/comment/128254#Comment_128254
Done it, and nothing changed... It's not a cache or reset problem... I discussed those issues for an entire week with the support and they told me that they had tons of other people claiming the same issues (schedule charging not functioning and slow charge beeing fast above all the others) and they said that it was a problem that could have been fixed only with an update... And now, at least three update after, i still have those problems, like EVERY SINGLE other people i asked about: i asked to more than 10 people with a rogphone 3, and ALL of them have the same issues...
10-29-2020 03:03 PM
10-30-2020 09:50 AM
BlackAsI did not "measured" it... I simply compared with the fast normal charging and it's almost identical in the time to charge... Also it says in the description (and there is a chart also in it) that it should charge the phone constantly at the exact same speed... But from 0 to 85 it's waaaaaaay faster than from 85 to 100... Not speaking about the heat that it's identically high in fast and slow chargingHow are you measuring the watt out put from the charger to establish slow charge not working are you using a clamp meter then converting amperage to watts ? I haven't checked mine just assumed it was working cause I turned it on. I haven't tried the scheduled charging on mine either.
11-03-2020 01:17 AM
Gustav_ASUSLittle update: i downloaded the update today (n.17.0823.2009.99) and i have the same issue unresolved again. Nothing changed.@pranoj24 Sorry should have been more clear. Can you do a recording where you reset the cache of PowerMaster and then set the time for scheduled charging?
