Schedule charging is not working and time changing randomly
pranoj24
Model Name: Asus Rog Phone 3
Firmware Version: .78
Rooted or not: not
Frequency of Occurrence: everytime
APP Name & APP Version (If your issue relates to the app): battery=>powermaster=>schedule charging
Hello!
When I setup schedule charging time is changing randomly. Is it a bug? @Gustav_ASUS @Anders_ASUS @Anders @Gustav_ASUS @andelocia
23 REPLIES 23
pranoj24
Gustav_ASUS
@pranoj24 Sorry should have been more clear. Can you do a recording where you reset the cache of PowerMaster and then set the time for scheduled charging?
@Gustav_ASUS i clear cache of powermaster also mobile manager still same issue.
AmitGarde
Community Legend II
pranoj24
  1. Model Name: Asus Rog Phone 3
  2. Firmware Version: .78
  3. Rooted or not: not
  4. Frequency of Occurrence: everytime
  5. APP Name & APP Version (If your issue relates to the app): battery=>powermaster=>schedule charging
Hello!
I use to face this same issue with my Zenfone 5z even after many workarounds issue was still the same , but this schedule charging only started to work perfectly after factory data reset this is the only way which will fix this issue
Saifuddin
Zen Master III
amitgarde3
https://zentalk.asus.com/en/discussion/38108/schedule-charging-is-not-working-and-time-changing-rand...
I had done factory reset but both slow charging and fast charging dont work at all
Saifuddin
Zen Master III
amitgarde3
Is there any way to fully wipe the software and install full and fresh rogui software again, if there is a way then i will try it
itopinonavevano
amitgarde3
Done it, and nothing changed... It's not a cache or reset problem... I discussed those issues for an entire week with the support and they told me that they had tons of other people claiming the same issues (schedule charging not functioning and slow charge beeing fast above all the others) and they said that it was a problem that could have been fixed only with an update... And now, at least three update after, i still have those problems, like EVERY SINGLE other people i asked about: i asked to more than 10 people with a rogphone 3, and ALL of them have the same issues...
