Rog phone 3 suddenly blackscreen and no led indicator of charging
devicentextian
Rising Star II
This what im doing when it happens
So i just finished charging the phone for about 10mins it's also locked to 80% then started scrolling through internet
while im scrolling the screen suddenly went black i though it just goes to sleep mode so i tried opening it but it just vibrate. i tried charging it then it led shows it not charging since it shows no light.
after an hour or 2 it opened i got into the menu then the phone went black again..
now earlier 10 hours since it went black again i tried connecting it to my laptop it suddenly shows light into led indicator it means it was charging, before i also tried to charge it through my laptop but no response. now  i tried opening it and just keeping vibrate when i tried.. then i tried holding the power and down volume at the same time now it opens and charging? it works properly right now but i don't know what cause this ?
1 ACCEPTED SOLUTION
Accepted Solutions
devicentextian
Rising Star II
This issue is now currently fixed after It opened once again I factory reset it 3 times the first one still turned my phone off and does the same issue then 2nd time I factory reset it through settings and I factory reset it again through Power + volume down just to make sure, now the phone is currently working properly for 2 days now, idk if it's hardware or software issue since one of the symptoms is it won't charge.
keren_ASUS
Hi @devicentextian
I'm so sorry to hear about this issue! Can you please reach out to the service team as this could be a hardware issue?
https://www.asus.com/ph/support/callus/
devicentextian
Rising Star II
ZenBot
Community Manager
Community Manager
