03-04-2023 03:29 PM
Model Name: Asus ROG phone 6D ultimate
Firmware Version:
Rooted or not: No
Frequency of Occurrence: always
I have my momentum true wireless 3 earbuds (Sennheiser) and when i try to use the aptx codec i realize i don't have the option, it only shows SBC and AAC to choose from.
I have android 13 lates versión and i don't know what else to do.
I use the earbuds on another phone and it's shows aptx right away.
Solved! Go to Solution.
03-04-2023 03:38 PM
03-04-2023 03:38 PM
Its because of the mediatek SOC, remember aptx belongs to Qualcomm,
03-04-2023 03:44 PM
That's true 😮 so i can never get aptx or something better than AAC ?
03-06-2023 02:03 AM
Check your device
Unplug the device, then plug it back in. If it's a Bluetooth device, ensure it is turned on and connected properly. Make sure that you are using a supported USB device for Zoom
Regards,
Will
