GPS not working right on Android 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-28-2021 08:34 AM
Model Name: Rog Phone 3
Firmware Version: last two a11 versions
Rooted or not: not
Frequency of Occurrence: non stop
Im using Maps everyday and I have a problem with location. It refreshes very, very slow and navigation is not usable.
I need to clear Google Play Services cache and storage every time I open Maps or other navigation app to work properly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-30-2021 01:39 AM
kpetrovHave you tried to uninstall updates and don't update the latest to see if it is better?Please tell us some basic information before asking for help:
- Model Name: Rog Phone 3
- Firmware Version: last two a11 versions
- Rooted or not: not
- Frequency of Occurrence: non stop
- APP Name & APP Version (If your issue relates to the app):
Is it only Maps app that's the problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-30-2021 07:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-31-2021 11:57 PM
What I had done and still not working.
1. Clear cache and storage in Google map.
2. Uninstall and reinstall Google map.
3. Reinstall A11. Only overwrite, not factory reset.
Now only left factory reset which I want to avoid at all cost.
Apps use.
Google Map, Waze.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-04-2021 03:40 AM
kpetrovPlease tell us some basic information before asking for help:
wayne.hbwGo to Google Play Store and download GPS STatus Toolbox.I'm having this problem as well. A10 no such issues. Now the GPS seems like dropping very often. I can keep seeing that the "searching for GPS." It can locate my position but very slowly. When I'm on the move, it will update extremely slow till no update.
Apps use.
Google Map, Waze.
Press on top left and then hit the menu. Press on Manage A-GPS State and press on Download. You will need to be connected to the internet though.
Once done, go outside and start your maps app, it should hopefully start to use the satellites.
