Asus ROG 3 double tap to lock not working
soham1995
Asus ROG 3 , version : 17.0823.2007.58
I have turned on double tap to lock and when I double tap to lock anywhere on a blank space on my home screen nothing works , when I double tap on the lock screen only it works .
7 REPLIES 7
GameOjas
Rising Star I
Gustav_ASUS
@soham1995 Would it be possible for you to record a video so we can see for ourselves? It's working as intended on all our test devices running the same firmware.
Double tap only works if you press screen hard and with constant speed....
If you tap little bit slow or faster it sometimes doesn't recognise it.
soham1995
A feature like OnePlus and Xiaomi have . Double tap anywhere on the home screen to lock. Thats what it says , when you turn on the setting in the information
Anders_ASUS
Hall of Fame III
soham1995
I've sent you a PM with instructions on how to log your device so we can find out why this is not working for you.
Just make sure you're one the .70 fw before you start logging
