Zenpad10 (Z300M) Power button not working.
Matalay
Hello, the power button is not working. (The hardware of the power button is intact.) Recovery mode does not work. I cannot install software. Fastboot only works. There is a bootloader lock. Can you send me a file to open? Or what path should I follow?
Serial number: H4NPC**********
Falcon_ASUS
@Matalay
I'm sorry to inform you that the model you are using is an older model that is no longer supported, and therefore, we are unable to perform any unlocking operations. Regarding the reported issue, it may be caused by a motherboard malfunction. Since the device is likely out of warranty, there will be diagnostic fees and costs for any required parts during the repair process. We apologize for any inconvenience caused.
