Wifi icon not showing
Evagelia
Hello,
I recently performed a clean installation (format) of Windows 11 Pro on my Asus Rog Zephyrus G16 but the WiFi icon is not showing on the bottom right of the taskbar. I've checked all the possible solutions on the internet but nothing seems to work. The Mediatek Wlan driver doesn't appear on the device manager, so I installed it manually but I'm getting an error code 37 which doesn't let me finish the installation. The network on the bios is unlocked, I've performed hardware diagnostics on the network card and says it's fine. I've also used netsh commands on the command line but still nothing, please help.
Thanks in advance.
Falcon_ASUS
@Evagelia
It is recommended that you refer to the following FAQ for troubleshooting.
If the wireless network still does not appear in Device Manager, we suggest taking your laptop to a service center for further inspection.
