Unknown USB Device (Device Descriptor Request Failed) at model FA506NC
kakarot5721
Model: FA506NC
I'm pretty sure this is a Bluetooth error. Because during the driver update process, due to the display loss and loss of connection to both wifi and bluetooth, I updated the Bluetooth driver on the "MyASUS" app and checked in "Device Manager" and only saw this error appear in "Universal Serial Bus controllers". What should I do?
Falcon_ASUS
@kakarot5721
We recommend uninstalling the device, restarting your laptop, and then reinstalling the driver to check if the issue is resolved.
[Windows 11/10] Troubleshooting - Bluetooth Functionality Anomaly Issue
Product Support For FA506NC
If the problem persists, it may be a hardware failure. We suggest bringing your laptop to a service center for further inspection.
