There may be an issue with the fan
jphanna00
System:
Battery or AC:
Model: Tuf fx505gt
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
19 REPLIES 19
Blake_ASUS
Community Legend II
Hello Devil's Ambit,
Thank you so much for the information.
This issue is now under investigation and I will keep you updated.
jphanna00
I updated the bios and all the drives 3 times. I formatted the pc 2 times, one of them was fully clean the drives. I checked if it was a hardware problem, but the fans are perfectly fine. The problem is still there, I pc sometimes run at minimal capacity and when I check the fans in Armoury crate, it says that my gpu and cpu are at power saving even in turbo mode. I tried everything and nothing seems to work.
jphanna00
Power saving is not turned on and power option is set to high performance.
Blake_ASUS
Community Legend II
Hello jphanna00,
Thank you for the update.
There will be a new version of MyASUS releasing soon.
I will keep you all informed when it is out.
jairon_tarnate
Hello OP, have you solved your problem? I have the same model as you and had the same problem. Luckily, I found a workaround solution on other thread.
